-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   Leveling Kitchen Cabinets for Granite - how level?? (http://www.diychatroom.com/f80/leveling-kitchen-cabinets-granite-how-level-38762/)
vsheetz 02-20-2009 02:58 PM
Doing a whole hours remodel/update - U shaped kitchen
The past couple days I had a company come in and install new cabinets in my kitchen - they look great and the installers seemed to know what they are doing. They did encounter the concrete slab floor to be falling away from one side of the kitchen to the other - with the cabinets starting on the high side with no shims under them to having 3/4" plus shims on the other side of the kitchen.
Today I have the granite installers from the same company here installing granite countertops. They are having problems with the cabinets being not very level. First they screwed 1/2" plywood to the top of the cabinets. When placing an 8' level across the sink base and the cabinets on either side, one can readily rock the level with maybe 3/8 difference end to end. They are placing several 1"x2" x 1/8" thick shims around under the granite to bring it level.
The question - is this normal and ok to have to shim under the granite like this? My expection was that the cabinets would be quite level with the granite uniformly in contact and supported by the plywood.
thx!
Vince
detroitMi 02-20-2009 03:12 PM
countertop
Usually they install the cabinets level then after that "here in Michigan "they install the countertop without plywood,shims are often used while installing the granite countertop to make sure it comes up even. You must live somwhere in the west, over there they use the plywood first then install the countertop in top of it. Have a great one
http://www.diychatroom.com/images/st...ser_online.gif
Scuba_Dave 02-20-2009 03:19 PM
If they installed the cabinets they should be perfectly level before they install the granite. There's really no excuse for installing new cabinets that are not level. My last kitchen dropped 3" or more on one side & my cabinets were level
I installed a granite hearth
I put enough thinset down to bed the granite & allow it to level out
If the counter isn't level then the granite may crack
angus242 02-20-2009 04:20 PM
Vince,
That was a poor cabinet installation.
When I install cabinets they are all level....at the same level. If you had counters on either side of the room and an island, you could run a level from any 2 spots in the room and they would be dead on.
That's how you install cabinets.
Unfortunately, it's not uncommon for granite installers to come across cabinets that aren't level. They do the best they can to shim to get the counters nice and level. Not much else they can do. Actually, some installers will charge extra for having to level. That's the cabinet installers job!
Bob Mariani 02-20-2009 05:11 PM
they must be perfectly level in both directions. Otherwise as posted the installer will shim to level. If they do not, the seams will not line up at the top and the edge.
vsheetz 02-20-2009 11:02 PM
It was fixed - thanks!
As they progressed around the kitchen it got even worse - the granite was having to be spaced up to where the plywood was showing under the bullnosed front edge - I questioned it and was told the cabinet installer would come back and put a piece of trim to cover it!
I declared it unacceptable and called a halt. A call to the company office and the cabinet installer was back onsite with an hour. All the base cabinets were properly re-leveled and the granite went on without shims.
Thanks everyone for the excellent and prompt replies - a HUGE help!
Vince
vsheetz 02-20-2009 11:06 PM
Yup - house is in SoCal, with plywood on top of the cabinets and a bullnosed edge overhanging the front of the cabinets.
Scuba_Dave 02-21-2009 12:01 AM
That's great!!
Even if they shimmed it there would have been large areas unsupported
Can you imagine someone sitting up on the counter??
Snap!! :eek:
LeviDIY 10-21-2009 02:47 PM
More base cabinet leveling in prep for granite...
Sorry to resurect an older thread, but I thought my question would further add to the above discussion... :whistling2:
In levelling the base cabinets in prep for granite, how do you shim up a back corner of a cabinet up against a corner of 2 kitchen walls? I'm finding it almost impossible to get a shim back there. I'm off by less than 1/8" of level front to back and side to side... I want it "perfect" as mentioned above, but I'm about to go crazy and start ripping up the floor. :jester:
retired guy 60 10-21-2009 05:32 PM
As I understand it, you want the cabinet not only level front to back but also level with any adjoining cabinet but you can't get the shims back there with the cabinet in place. Here's what I would do. I would use a two foot level and using shims cut from a scrap 2x4, I would level the floor (prior to installing the cabinet) both front to back and side to side. I would make a bunch of shims from a scrap of 2x4 and increase the the thickness of each shim by 1/16 of an inch starting with the thickness suggested by my initial use of the level. I would make sure that the shims produced a level floor with regard to any adjoining cabinets. If the cabinet was made properly, it should be level once it is placed over the shims since the base is now perfectly level. I would tack the rear shims down so they don't shift during installation. You can fine tune by adding front shims if necessary since the front of the cabinet is accessable. There are probably other ways to accomplish this but this is the way I'd do it.
skymaster 10-21-2009 05:45 PM
pull the cabinet, tack glue a shim on the floor, reset the cabinet, if need be you can also scribe the cabinet that way u dont need shims, HOWEVER be aware if you scribe one most likely you will have to do ALL cause the height of the cabinet will decrease when u scribe the base.
Second and easiest way is to hold cabinet level, push tight against the wall and just screw it into the wall, if there is a gap between cab back and wall then just put shim to fill gap and screw thru it.
Daniel Holzman 10-21-2009 06:15 PM
You can always use self levelling compound on the floor, this effectively guarantees a stable, level surface to start with. But realistically, there is no such thing as a perfectly square cabinet, there are always tolerances. Also, the wall behind your cabinet is almost certainly not perfectly plumb, and is likely to "wobble" both vertically and horizontally along the line of cabinets, possibly as much as 1/2 an inch. If you push the cabinets hard up against the wall and screw them to the wall (which you probably want to do in earthquake country), the tops of the cabinets are not going to be perfectly level.
When I had my granite installed on my kitchen cabinets (all of which I built myself), there were gaps of up to 1/4 inch between the granite and parts of the cabinet tops, which was absolutely no problem for the installers, they simply put shims in, and finished the install using silicone sealant. I figured in a 50 year old house, with 20 feet of cabinet, a quarter of an inch wasn't bad.
mjuncker 03-02-2012 08:36 PM
Leveling is a very important part of cabinet installation process
If the cabinets aren't fabricated plumb and properly leveled in all directions when installed the cabinet doors and drawers won't align. It throws everything off including the counter top. Using all the proper tools to level is crucial. There is not such thing as level floors and walls, the installer needs to shim cabinets to level them to the existing irregular surfaces. If there are upper cabinets installed at the ceiling and the ceiling is uneven the best way on lower ceiling heights is to correct the ceiling prior to installation. The cost of scrapping the old texture and retexturing isn't that expensive. I have pictures reflecting the out come of cabinets not being properly leveled.
DangerMouse 03-02-2012 08:54 PM
You DO realize this thread is 3 years old, right?
DM
