Leveling Existing Cabinets - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-16-2012, 05:58 AM   #1
leveling existing cabinets
we have custom cabinets in an older home, we are having siestone counter tops put in, the guy came out to make a template but said he could not do it until they were level, how do we do this to existin cabinets?
gigijaro is offline   Reply With Quote
Old 06-16-2012, 06:14 AM   #2
Rewards Points: 14,312
I'd be checking out the floor to see how out of level it is first.
Almost any older home I've ever worked on has a sag in the middle of the rooms from to long a span, under sized floor joist, insect or fungus damage.
Address this from under the floor and the out of level issue should go away.
gigijaro (06-16-2012)
Old 06-16-2012, 06:36 AM   #3
DIY staff
Rewards Points: 7,174
Post some pictures----the odds are you will need to remove the old counter tops---un screw then from the wall and reinstall them properly----
Many of us have experience with that process---If that sounds like a difficult task--It's usually not---Pictures will help us explain the process.
A skilled cabinet installer could be hired if you aren't able to do this work yourself.
Should I install 5/16" over existing 3/4"? AMass44 Flooring 0 03-05-2012 10:05 PM
Leveling Kitchen Cabinets for Granite - how level?? vsheetz Kitchen & Bath Remodeling 13 03-02-2012 07:54 PM
leveling an existing walk in shower mike garner Kitchen & Bath Remodeling 2 02-18-2012 12:56 PM
new range hood with existing cabinets cook Carpentry 6 01-26-2010 01:09 PM
leveling base cabinets for granite install levelman Carpentry 3 10-24-2009 05:10 PM
