Lazy Susan Kitchen Cabinet Alignment - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-19-2012, 12:29 PM   #1
lazy susan kitchen cabinet alignment
I have a lazy susan corner kitchen cabinet in the lower cabinets. It works fine, but when it is closed, it no longer lines up. the right side of the door is open a couple inches and the left side is inside the cabinet.
Can't figure out what to adjust - please help.
winstoncup is offline   Reply With Quote
Old 05-19-2012, 08:12 PM   #2
DIY staff
Rewards Points: 7,174
There are several styles of lazy susans--some have doors attached to the rotating shelves--others have bifold doors attached to the cabinet--
what do you have?
A picture will help if you can figure out how to post it.
Old 05-19-2012, 08:34 PM   #3
what do you have?
it is the type where the doors are attached to the shelves. It is approximately 17 - 20 years old. Took a pic but haven't been able to find my cable to attach to my pc. will try with cell phone camera on Sunday
Old 05-19-2012, 09:05 PM   #4
DIY staff
It has a problem--the lower or upper bearing cup may have come loose and shifter over--see if the shaft is plumb or leaning---
Old 01-19-2013, 07:45 PM   #5
I had this same problem. It worked perfectly fine except for the doors didn't align when closed. I finally figured out how to align it. This type has a plastic cylinder at the top, with a vertical notch on its side, that fits into a ridge on a metal plate. I loosen the nut and bolt on the metal clamp that holds this cylinder in place. I rotated the lazy suan until the notch fit on the ridge. I discovered that if I turned the lazy susan CLOCKWISE, the notch stayed in place, and I could turn it all the way around to align the doors. Then, to open it back up without losing this alignment, I turned the lazy susan COUNTER-CLOCKWISE. Then I tightened the nut and bolt, and tested the doors. It lines up perfectly now!
IlikeDIY is offline   Reply With Quote
The Following User Says Thank You to IlikeDIY For This Useful Post:
oh'mike (01-20-2013)
Old 01-20-2013, 06:41 AM   #6
DIY staff
Good tip!---------------
repairing a lazy susan Ken Murphy General DIY Discussions 10 02-13-2012 04:25 PM
Extendable Shelve with Lazy Susan dzirkelb General DIY Discussions 4 08-22-2010 11:30 AM
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 11:44 AM
filler on kitchen cabinet timbo59 Carpentry 7 05-05-2010 08:19 AM
Kitchen Cabinet PROBLEM! zetti1102 Painting 6 09-17-2009 08:09 PM
