-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   lazy susan kitchen cabinet alignment (http://www.diychatroom.com/f80/lazy-susan-kitchen-cabinet-alignment-144255/)
winstoncup 05-19-2012 01:29 PM
I have a lazy susan corner kitchen cabinet in the lower cabinets. It works fine, but when it is closed, it no longer lines up. the right side of the door is open a couple inches and the left side is inside the cabinet.
Can't figure out what to adjust - please help.
oh'mike 05-19-2012 09:12 PM
There are several styles of lazy susans--some have doors attached to the rotating shelves--others have bifold doors attached to the cabinet--
what do you have?
A picture will help if you can figure out how to post it.
winstoncup 05-19-2012 09:34 PM
what do you have?
it is the type where the doors are attached to the shelves. It is approximately 17 - 20 years old. Took a pic but haven't been able to find my cable to attach to my pc. will try with cell phone camera on Sunday
oh'mike 05-19-2012 10:05 PM
It has a problem--the lower or upper bearing cup may have come loose and shifter over--see if the shaft is plumb or leaning---
IlikeDIY 01-19-2013 08:45 PM
I had this same problem. It worked perfectly fine except for the doors didn't align when closed. I finally figured out how to align it. This type has a plastic cylinder at the top, with a vertical notch on its side, that fits into a ridge on a metal plate. I loosen the nut and bolt on the metal clamp that holds this cylinder in place. I rotated the lazy suan until the notch fit on the ridge. I discovered that if I turned the lazy susan CLOCKWISE, the notch stayed in place, and I could turn it all the way around to align the doors. Then, to open it back up without losing this alignment, I turned the lazy susan COUNTER-CLOCKWISE. Then I tightened the nut and bolt, and tested the doors. It lines up perfectly now!
oh'mike 01-20-2013 07:41 AM
Good tip!---------------
