Laminate Countertop Edge Repair - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-19-2015, 11:07 AM   #1
Rewards Points: 1,646
Laminate countertop edge repair
Had the laminate edge came off and broke loose. I cut it square...but now what's the best way to fix it?
I couldn't find a matching pattern.
Re-edge the entire length all the way around?
I have seen some "retro" metal edging.
Are these easy to do?
miamicuse is offline   Reply With Quote
Old 01-19-2015, 11:54 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 536
It is going to be easier to replace that edging with wood, trying to get HPL cut that straight and smooth to match up to the bottom of the slight over hang lip where the old edging was, is next to impossible. If you had the old piece you could cover the edging with a towel the use a hot iron to stick it back.
You will have to scrape the glue off the slight over hange before installing new edging.
That metal edge is a "T" type edging, you would have to slot the edge of the top to use that. You would have to remove the slight lip before you could slot.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-19-2015, 12:03 PM   #3
Thanks, by wood you mean a thin veneer or a wood trim? If wood trim I was also thinking about that but when it gets to the space for the range, the space is very tight and no room for the thickness of two pieces of trim on either sides.
Old 01-19-2015, 01:04 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 536
I don't think you would be happy with a veneer, it wouldn't hold up long. A thicker wood edge is what I had in mind. HPL would be tough to install without a gap where the top piece meets the edging.
Jim
laminate countertop help moni71487 Interior Decorating 18 10-03-2012 06:39 PM
Granite Tile vs. Laminate Countertop (Kitchen) Cow 9 Kitchen & Bath Remodeling 7 01-25-2012 11:53 AM
Tile backsplash if have laminate with wood edge?? simiesue Remodeling 4 04-12-2011 12:15 PM
Cutting Plastic Laminate counter top edge (hot bit roller) Steamer2 Remodeling 2 04-01-2010 06:41 AM
laminate transition edge moneymgmt Flooring 0 03-16-2010 10:01 AM
