Laminate Countertop Butt Joint - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-10-2012, 11:54 AM   #1
Laminate countertop butt joint
Hey all, remodeling my kitchen and I seem to have a common problem but there are many countering answers on here, pun intended.
Longer than 10' counter, u- shaped kitchen with a 2ft mitered corner to the left and stove to the right
I need to but a joint and would like to seam at the sink, but there are no bolts for butt joints on the box store pre fab laminate tops with backsplash. Use clamps some how? Spreader? Help please!
Rono8582 is offline   Reply With Quote
Old 11-16-2012, 09:04 AM   #2
Bump !
Old 11-16-2012, 09:57 AM   #3
Rewards Points: 3,130
The bolts used for this are called draw bolts. You can buy a draw bolt template and make the pockets for them with a router.
The Following User Says Thank You to md2lgyk For This Useful Post:
mae-ling (11-16-2012)
Old 11-16-2012, 11:02 AM   #4
Rewards Points: 2,210
Sorry I missed this before.
There is also a color matched seam sealer you can put in the seem where they join.
mae-ling is offline   Reply With Quote
Old 11-16-2012, 01:32 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 192
A joint at the sink is frowned on because the possibility of water getting to the substrate and ruining the top, not to mention not much area to hold the bolts.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
GBrackins (11-16-2012)
Old 11-16-2012, 02:12 PM   #6
Missed the sink joins - thought it was the mitre's, right on BIG
The Following User Says Thank You to mae-ling For This Useful Post:
BigJim (11-16-2012)
Laminate countertop joint Comcneil Kitchen & Bath Remodeling 8 06-13-2012 07:23 PM
laminate countertop question photopeter Kitchen & Bath Remodeling 2 12-18-2011 03:32 PM
Laminate countertop mitered joint question lemmy999 General DIY Discussions 5 10-18-2011 05:54 PM
butt joint pre-fab laminate countertop mrennolds Kitchen & Bath Remodeling 3 07-05-2010 12:34 AM
Mitre or butt joint for laminate countertops with roundover edge? tigereye Kitchen & Bath Remodeling 1 02-04-2010 11:33 AM
