Laminate Counter End Cap - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-22-2008, 10:12 AM   #1
wilderstyle
Hey, can someone tell me what type of adhesive to use for adding the endcap piece of laminate to my laminate countertop? Any tips will be helpful. Thanks
wilderstyle is offline   Reply With Quote
Old 11-22-2008, 04:18 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Contact cement. Use a roller too.
- Build Well -
Old 11-22-2008, 04:49 PM   #3
wilderstyle
Sooooo, how do I trim the edges? The kit has a straight piece for the bar, but the edges are not rounded like the bar. The other pieces are formed for my range slot and are shaped like a counter with backsplash. I think I can align the front edge and cut it at the back edge. How do I do those cuts?
Old 11-23-2008, 01:06 PM   #4
3M brand Super 77 in a spray can should hould the end cap on there, just mask everything off where you don't want overspray, for less clean up. Once on, use a router with a flush cut bit. Clean up the edges and round it off slightly with a fine grit rasp, or file. Be carefule, laminate is easy to burn, when using the rasp, it's easy to go through the top layer and expose the white underneath, but you can use a colored permanent marker to touch it up.
A roller is certainly the easiest and most effective way, but you press it on good enough just with the palm of your hand, just becareful not to cut it on rough edges of laminate. You can pretty much use anything that'll give you leverage and slide across it easily without scratching it.
Jeeper1970 is offline   Reply With Quote
Laminate Counter Tops, clear coat? joedreamliner787 Painting 9 06-16-2011 03:55 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
Cutting off 3" of laminate counter top in place 4just1don Building & Construction 3 09-27-2008 09:33 PM
Applying laminate to waterfall edge on a counter top. lmpasker Carpentry 2 04-02-2008 06:34 PM
Repairing scratch in laminate counter Keyo77 General DIY Discussions 2 02-03-2008 01:00 PM
