-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   Laminate Counter End Cap (http://www.diychatroom.com/f80/laminate-counter-end-cap-32389/)
wilderstyle 11-22-2008 10:12 AM
Hey, can someone tell me what type of adhesive to use for adding the endcap piece of laminate to my laminate countertop? Any tips will be helpful. :whistling2:Thanks
AtlanticWBConst. 11-22-2008 04:18 PM
Contact cement. Use a roller too.
wilderstyle 11-22-2008 04:49 PM
Sooooo, how do I trim the edges? The kit has a straight piece for the bar, but the edges are not rounded like the bar. The other pieces are formed for my range slot and are shaped like a counter with backsplash. I think I can align the front edge and cut it at the back edge. How do I do those cuts?
Jeeper1970 11-23-2008 01:06 PM
3M brand Super 77 in a spray can should hould the end cap on there, just mask everything off where you don't want overspray, for less clean up. Once on, use a router with a flush cut bit. Clean up the edges and round it off slightly with a fine grit rasp, or file. Be carefule, laminate is easy to burn, when using the rasp, it's easy to go through the top layer and expose the white underneath, but you can use a colored permanent marker to touch it up.
A roller is certainly the easiest and most effective way, but you press it on good enough just with the palm of your hand, just becareful not to cut it on rough edges of laminate. You can pretty much use anything that'll give you leverage and slide across it easily without scratching it.
