Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 01-31-2011, 07:07 PM   #1
Kitchen wall paneling and cabinets
Hello, this is my first time using these forums so excuse me if I miss any details.
I recently decided to take down the 1970's wood paneling from our kitchen and dining areas and replace it with sheetrock and concrete backer board so we can put up a backsplash.
We're on a tight budget and do things as we can afford them and unfortunately new kitchen cabinets are nowhere near being in our budget. My plan was to take the cabinets down and off the walls so we can put up the Sheetrock (as well as insulate between the garage and kitchen which has none at the moment). I was then going to sand the cabinets down and restain them (if possible due to their age).
My main concern now is the cabinet boxes are nailed in and not screwed in. After 30-40 years, what are the risks of me ruining the boxes trying to get them off the wall? I really can't see any other way of getting them off without using a crowbar and with the way the upper body of the boxes are constructed I am betting that will break the wood before the nails pull out of the studs.
Any advice is appreciated.
dazoli is offline   Reply With Quote
Old 01-31-2011, 08:36 PM   #2
Did they use common or finish nails? You can use a tool called a, "cats paw" to take out the nails, but it will leave a mark on the wood. You can cover the damage with a thin covering board. The difficult issue will be the connections between the cabinets. If you take out a line of cabinets, you can minimize the visual issue.
Ron
Old 01-31-2011, 08:50 PM   #3
They're common nails--fairly large. The whole cabinet box/structure is one large piece (just short of 8 feet long) with only 4 nails near both ends.
Old 01-31-2011, 09:04 PM   #4
Super Moderator
Are you creative?-----The best way to remove the cabinets is with a home made hole saw---
Pick up an old push rod from your mechanic--you may need a good sized one from a diesel engine--
Saw it in half---file some teeth into the cut end---chuck that into your drill---place the 'hole saw'
over the nail and cut the hole--
You will leave the nail and a little plug of wood in the wall--soon the cabinets will be free--
A plug cutter set might do the same thing---We used to strip barn wood using the push rod cutters-
---Mike--
Old 01-31-2011, 09:17 PM   #5
Well, my father-in-law might be that creative. I don't have quite enough experience to be that creative on my own. I'll give him a shout tomorrow and see if that sounds like something he thinks we could cook up. Thanks for the idea, Mike.
The Following User Says Thank You to dazoli For This Useful Post:
oh'mike (01-31-2011)
Old 01-31-2011, 09:23 PM   #6
Or you can get these.
Ron
Old 01-31-2011, 09:25 PM   #7
Are those the plug cutter's Mike mentioned above?
Old 01-31-2011, 09:42 PM   #8
Same family, smaller cousins used for broken screws and the like. I picked them up at Rocklers.
Ron
Old 01-31-2011, 09:57 PM   #9
Excellent. Just checked their web page. Thought maybe it wouldn't go deep enough but if it makes it through the cabinet board then we just yank the nails out once we take the cabinets down.
Thanks much!
Old 01-31-2011, 10:18 PM   #10
Thanks much!
The nailing rail should be about 3/4"
Ron
Old 01-31-2011, 11:13 PM   #11
Super Moderator
Good research Ron----we used to make those ourselves--I had no idea they were available already done.
Old 01-31-2011, 11:30 PM   #12
I got these years ago when I snapped off a brass screw because I was in too much of a rush to drill a pilot hole. Saved me a whole bunch of time not drilling that hole.
Ron
Old 01-31-2011, 11:56 PM   #13
Very cool. Glad my question helped someone that was trying to help me.
Old 02-01-2011, 12:12 AM   #14
Hey Ron, just curious: it looks like those have teeth on both ends. How do they attach to a drill? (might be stupid question)
Old 02-01-2011, 07:20 AM   #15
You put it in the drill the same way you do any bit. This one just has teeth on both sides.
Ron
Installing Kitchen Cabinets Questions ?? Tom5151 Remodeling 11 11-08-2010 08:29 PM
Kitchen "Facelift"- on a Budget EZe Project Showcase 9 09-15-2010 09:38 PM
Painting Kitchen Cabinet Color Ideas - Help! JLSchultz3172 Interior Decorating 6 03-19-2010 07:15 PM
Tile over paneling? Eric_ht Remodeling 2 11-24-2007 10:27 AM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
