Kitchen Tile Aesthetic Question - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-27-2010, 07:12 PM   #1
Kitchen tile aesthetic question
My back splash is "L" shaped. The vast majority of it is 12 3/4". It jumps up to 17" behind the range. I am using 4" ceramic that I am going to tilt on a diaganal and make a diamond pattern. The electrician in me screams to center the tile vertically, which will create an awkward pattern on the bottom, which I can see as well as the top which I have to squat to see. If I dropped the tiles down just a bit I can have a half then a whole tile on the bottom and whatever happens up top just happens. Is that the correct way to do it???
Also do I start tileing from the corner??? so I have half and whole cuts there and work out in both directions?
Thanks in advance guys and gals
Andy
Andy-n-ATL is offline   Reply With Quote
Old 04-27-2010, 10:28 PM   #2
Your best bet is to draw it all out on paper first, as you don't want to leave gaps in the top or bottom-- it should all look symmetrical and like it was planned to fit the space. Are you using any decorative tile around the edges-- that might be a way to cover some of the smaller gaps.
Another thought, however, is to make the taller area by the stove a different pattern or coordinating tile to make it a focal point.
Allison1888 is offline   Reply With Quote
Old 04-27-2010, 11:07 PM   #3
Military Mom of 4
Snav's Avatar
Most tiled or brick backsplashes I've seen above ranges have a square or rectangle that's formed and then filled.
http://img.diynetwork.com/DIY/2007/1...ksplash_lg.jpg
You don't have to buy expensive accents to make something like that look good. You can use a different size of the same tile - maybea different color - but I think just altering the direction of the tiles would be nice.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Two Questions about Kitchen Wall Tile sbazzle Kitchen & Bath Remodeling 15 04-23-2010 08:59 AM
Kitchen - tile backsplash grout Museseek Tiling, ceramics, marble 3 03-14-2010 12:52 PM
Replace kitchen tile without moving cabinets and countertop stubits Tiling, ceramics, marble 7 02-18-2010 10:56 AM
Kitchen question laur15 General DIY Discussions 3 11-24-2009 12:30 PM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 11:43 AM
