Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 11-15-2011, 04:37 PM   #1
kitchen sink screw up
I installed a new ss kitchen sink and cut the corners square instead of rounded. Do they make a ring that will go around the outside of the edge of the sink to cover the holes in the corners.
eridia is offline   Reply With Quote
Old 11-15-2011, 07:58 PM   #2
I don't think so, but try your local big box hw store (Lowe's, HD). One option might be to cut the rounded opening from another piece of wood and lay it on top of your square cutout. Caulk generously all around.
dougp23 is offline   Reply With Quote
Old 11-15-2011, 08:53 PM   #3
fabrk8r
fabrk8r's Avatar
I'd make you an escutcheon plate from 16 gauge #4 finish stainless steel and radius the corners to match your sink with a feathered edge all around, but I don't know where you are.
Call local sheet metal shops that do stainless fabrication and see if they can help you.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 11-15-2011, 09:44 PM   #4
Super Moderator
Can you return that sink and get one that will cover the goof?
Old 11-16-2011, 09:04 PM   #5
If there's an escutcheon for this it will come from the sink manufacturer.
Ron
B. Franklin 1759
Kitchen sink not draining, is it the vent? gdav Plumbing 18 02-12-2013 04:38 PM
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 04:17 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 11:10 AM
Sink or No Sink in Kitchen Island? Not Sure Plumbing 4 08-29-2006 08:37 PM
