Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 09-03-2012, 04:13 PM   #1
Kitchen remodel
I am going to sand and stain cabinets. New floor and new countertops. This might be a dumb question but is there a specific order those projects need to go in
troyer16 is offline   Reply With Quote
Old 09-03-2012, 05:09 PM   #2
Kitchen remodel
They could technically be done in any order. But if it were me, I'd do the cabinets, then the countertops, then the floor.
The Following User Says Thank You to md2lgyk For This Useful Post:
hand drive (09-03-2012)
Old 09-03-2012, 11:10 PM   #3
AHH, SPANS!!!
Kitchen remodel
start at the top and use painters tape and painters plastic between each step until at the floor..
hand drive is offline   Reply With Quote
Old 09-04-2012, 06:27 AM   #4
sdsester's Avatar
Kitchen remodel
Kind of depends on how you work.
You didn't mention painting but get the ceiling out of the way first. I would do walls last.
There is something to be said for refinishing your cabinets first but if you are not always gentle of touch and could ding them installing flooring or countertops you might at least hold off on your protective coats over the stain for last task.
If there is any chance you have to raise your cabinets to accommodate thicker flooring, you should obviously do the flooring first and then protect it.
sdsester is offline   Reply With Quote
Old 09-04-2012, 07:48 AM   #5
JOATMON
ddawg16's Avatar
Kitchen remodel
Floor last....that way you don't care what happens to the existing floor....
Counter tops just before you do the floor....
Everything else before that...
One piece of advice....put down a chunk of old carpet where you are doing the sanding....the dust and dirt will be worse than you think....the carpet piece will 'help' catch some of the dust and dirt.....
If possible, try to remove the cabinets and take them outside....
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 09-19-2012, 10:51 AM   #6
Kitchen remodel
id do the cabinets first so you dont get stain on your countertop, and do floors last so you dont mess them up with stain or debris
firsttimeremode is offline   Reply With Quote
Old 09-27-2012, 07:33 PM   #7
Kitchen remodel
cabinets first, counter-top second, and go floor last.
KatieW is offline   Reply With Quote
Kitchen remodel leiona Project Showcase 251 10-04-2012 10:58 AM
Kitchen Remodel ws450r Kitchen & Bath Remodeling 5 03-15-2012 12:14 AM
Kitchen remodel and venting joeh Plumbing 5 12-17-2011 07:38 PM
Unintended kitchen remodel Itsdanf Project Showcase 191 06-14-2010 12:23 PM
Kitchen remodel; ductwork pinkertonpv HVAC 3 02-18-2009 04:03 PM
