Kitchen Remod Question - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-30-2010, 06:03 AM   #1
Hi All,
Looking at painting my kitchen cabinets, very dark and gloomy. Have done all my HW and am ready to undertake the task...
My question is this.....At the ends of the cabinet walls (2 areas facing out), is a faux sticker type wood that matches the cabinet. Should I peel these off then paint of just paint right over them?
Thx in advance.
sschantz is offline   Reply With Quote
Old 04-30-2010, 06:44 AM   #2
Remodeling with Pride
Go to home depot, they sell a small wood veneer panel or a white bead board which looks great painted. Use construction glue like liquid nails to attach it.
LotzRenovations is offline   Reply With Quote
Old 04-30-2010, 01:18 PM   #3
Does this "veneer" really "peel off", like contact paper? Or is it a vinyl laminate on MDF or something. If it doesn't really peel off, I suggest you use a OIL BASED PRIMER before painting, if you do paint. I used Kilz OIL BASED on an entire mobile home. Tried other products, but this works miracles when it comes to making paint stick to vinyle. Do NOT use water based primers. They don't stick...PERIOD.
fitZ
3detailer is offline   Reply With Quote
Old 05-01-2010, 07:55 AM   #4
I believe it is a sticker of some sorts as it has air few bubbles in it. I definitely like this idea!!!
removing load-bearing walls and moving the kitchen WannaReno Remodeling 2 04-02-2010 05:05 PM
Kitchen reno, any better suggestions? mgarfield Remodeling 7 01-20-2010 03:37 PM
Ideas Regarding Kitchen Remodeling Kristal Kitchen & Bath Remodeling 2 12-20-2009 09:44 AM
Kitchen counter question axlmayhem General DIY Discussions 5 10-20-2008 09:32 AM
Kitchen walkway Design question dustandtools Building & Construction 1 10-14-2008 11:02 AM
