Kitchen Lighting - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-17-2011, 09:39 PM   #1
kitchen lighting
how many 5 inch recess cans do I need in a 12 by 8 kitchen
gek53 is offline   Reply With Quote
Old 02-19-2011, 07:32 AM   #2
kitchen lighting
Too broad a question. What are you hoping to gain from the new lights?? General lighting, task lighting, etc??? Kitchen layout, cabinets, main work spaces, etc???
Old 02-23-2011, 11:02 AM   #3
Rewards Points: 5,326
kitchen lighting
Also, what type of bulb are you going to use? What is the wattage limit on a 5" can? It's relative to the trim you're using. Open trims use the largest wattage bulbs and closed trims like eyeballs, use smaller wattage bulbs.
In the last few years, manufacturers have reduced the wattages you can put in these recessed lights. Open trim, 6" cans used to have a maximum capacity of 150 watts. If you look at the specs now, it's down to under 75 watts.
Ron
Kitchen Lighting Circuit sirsparksalot Electrical 1 02-16-2011 07:08 PM
12 volt kitchen cabinet lighting wire gauge? Help! :/ Lupinglade Electrical 16 09-25-2009 12:55 PM
Outlet & Lighting in kitchen remodel vjbozard Electrical 4 04-08-2009 03:17 PM
lighting on kitchen gfci allowed? frodo Electrical 48 02-14-2008 05:54 PM
lighting guideline's - kitchen remodel dcd22 Electrical 3 08-01-2007 12:50 PM
