11-26-2012, 08:59 PM
#1
Kitchen half wall for granite counter top
I am getting ready to make a half wall for a island that comes right off an interior wall.
I want to have this as a two tier island with seating on the other end between two 18" deep cabinets to support the granite counter top on the top tier.
I need two outlets that lay horizontal on the lower end in the half wall.
What is the standard height to raise up the 2nd tier in relation to the first tier? I was thinking it is 6" higher, but wasn't sure.
Is there any clearance issues that you need to account for to fit outlets between the two tiers?
When framing for this do you need a double top plate to support the granite weight?
Attached is a simple design for what I am trying to do
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
11-27-2012, 04:31 PM
#2
no comments or why are you doing it that way's? *lol*
11-27-2012, 10:31 PM
#3
sounds to me that you have it pretty well planned out.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
11-28-2012, 06:07 AM
#4
Super Moderator
Just a tip on building a floating wing wall with a lot of weight on top---
Extend the framing below the floor and anchor it to the floor joists---just on the free end---
As to height---grab a ruler and head out to a kitchen show room and find one that is comfortable.
You will want 4" for the electric---and the boxes will need to be let in to the framing---so get that done before any covering is installed---
11-29-2012, 09:34 PM
#5
what do you mean by "let into the framing"?
11-30-2012, 06:29 AM
#6
Super Moderator
If you want the free end extremely strong---cut a hole in the floor as large as the double 2x4 end---extend that through the hole and attach it firmly to the floor joists----some cross blocking might be required if the joists are not right where you want them---
As to the origin of that 'Let IN'----that's an old term describing cutting in a brace --English I believe --been in use for several hundred years--
11-30-2012, 06:44 AM
#7
ahh, alright.. well this is going on a concrete slab so no floor joists to worry about
11-30-2012, 06:59 AM
#8
Super Moderator
OOPS---disregard all that ---Your drawing helps---you have cabinets to add stability---I must have overlooked the drawing----you will be fine---
12-01-2012, 10:38 AM
#9
yeah. but you should still bolt the cabinets to the floor.
The Following User Says Thank You to Fix'n it For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
