Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 10-16-2012, 01:59 PM   #1
kitchen floor - What else can be used to build-up 1/2" over slab
Currently 1/2 plywood over concrete slab (way it was when we moved in)-
I can remove plywood which is nailed down- but I want to keep floor at same height. We are going to install vinyl tiles- What else can be used to bring floor up 1/2" over slab? Wood doesn't seem to be a good idea due to moisture
skinut2234 is offline   Reply With Quote
Old 10-16-2012, 10:23 PM   #2
JetSwet's Avatar
Are you above grade or below grade? Engineered hardwood can be glued together and is safe on above grade slab.
Other then that there Are what is called sleepers you can put down there strips that are safe for slab, then plywood over the sleepers, you will end up to be higher then what you are now.
JetSwet is offline   Reply With Quote
Old 10-22-2012, 02:29 PM   #3
above grade
kitchen floor advice Grumpy Flooring 4 03-21-2011 05:34 AM
linoleum floor for new kitchen evey Flooring 1 03-04-2011 05:43 PM
Sagging floor in kitchen...Advise please MGK01 Flooring 3 02-25-2011 01:34 PM
Rookie DIY'er: Kitchen Floor Project Gpike Flooring 2 02-25-2011 01:30 PM
