Kitchen Countertop Backsplash Problem - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-28-2011, 01:02 PM   #1
Rewards Points: 147
Kitchen Countertop Backsplash Problem (photo added)
Recently had some countertop installed by an unnamed Big Box store. The counter itself went fine. However, the backsplash is another story.
I guess my walls are not truly plumb because the backsplash doesnt really sit flush. In fact, in some places, there is as much as a 1/8 inch gap. Unsightly more than anything, but I also worry about water getting back there. (I finally got a photo added)
What is the best solution (the installer is not responsible for correction of backsplash due to non-plumb walls, per contract - I looked)? I could caulk but the gaps are pretty wide in places. Afraid it might just run down. But if I did, would folks suggest a clear caulk? Or something to match/compliment counter color?
Or could/should I maybe spray some Gap Filler like Great Stuff down in there first and let it dry. Then caulk? Gives caulk something to sit up on. Is there a chance that stuff could expand and damage backsplash?
Any advice is appreciated.
Cheers,
Brendan
tarheelblue is offline   Reply With Quote
Old 04-28-2011, 07:58 PM   #2
DIY staff
Rewards Points: 7,174
Without seeing the actual problem all I can say is caulk--clear paint-able latex or the closest color available---
Old 04-28-2011, 08:06 PM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Mike is right. Without a pic, all you're going to get are guesses.
One possibility: Google "backer rod". It's a stiff foam type rod that can be stuffed into larger gaps before caulking. Most likely found in with the weatherproofing stuff at that Big Box store. I would use it before using anything expanding. Then cover with caulk.
Old 04-28-2011, 08:26 PM   #4
Rewards Points: 147
thanks, guys. will see if I can compress a picture. file limit is 100kb
Old 04-28-2011, 08:33 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Can't photos be re-sized at some place like Photo-bucket?
I can't imagine what you have there.
XXX
Old 04-29-2011, 01:00 PM   #6
Rewards Points: 147
<bump>
Old 04-29-2011, 01:33 PM   #7
fabrk8r
fabrk8r's Avatar
If the largest gap truly is 1/8" then caulking should be no problem with no need to pre-fill. I'd use a latex caulk that matches the wall color.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 04-29-2011, 05:06 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Ah-ha, the photo has arrived.
There is not much you can do with that. You could stuff some foam backer-rod in the crack then caulk it but it will still be a "what-you-see-is-what-you-get" kind of a problem.
I gotta tell ya tarheel that is a path-of-least-resistance kind of installation job on the part of the installers. When that happens (and it does happen frequently) the installer usually gouges out some drywall here and there so that the backsplash fits into the wall just a little. That would take some extra effort however.
My suggestion is to (if you don't want to add ceramic tile to the wall overall) buy some ceramic tile bullnose only. Glue the bullnose to the wall. It will cover the unsightly gap and may even pretty things up a little.
That's all I got!
XXX
Remove kitchen backsplash? mindysand Remodeling 2 03-20-2011 01:42 PM
Kitchen - tile backsplash grout Museseek Tiling, ceramics, marble 3 03-14-2010 01:52 PM
Kitchen plywood countertop glue? ohman Flooring 5 06-24-2009 02:52 PM
Joining Marble Backsplash to Marble Countertop JLF377 Building & Construction 1 07-29-2007 01:27 PM
Tiled Kitchen Countertop forcheck Remodeling 3 02-21-2006 08:46 PM
