Kitchen Cabinets On Plaster Walls, TOGGLE? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-20-2012, 09:49 PM   #1
Rewards Points: 89
kitchen cabinets on plaster walls, TOGGLE?
Hello all,
Can someone please help me, installing a kitchen set into plaster walls, made of (in this layer from paint to brick) plaster, mesh, 1-2 inch air space, then block, then brick. There are no wooden slates. Any way, what would you suggest I install these wall cabnets with...
Toggle bolts? what size? ect....
I'm guessing the plasters at least 1/2 to 3/4 inch thick, plus wood on back of cabinets...
Any help would be great, Thanks
Chip
Baltimore
chipraynor is offline   Reply With Quote
Old 06-20-2012, 09:56 PM   #2
if i'm reading your post right, you have block 2-3 inches into the wall.
if so, i would suggest tapcon's, concrete screws, as the most secure way to hang these.
usually a package of them comes with a masonry bit for a cordless drill as well. assuming you have 2-3 inches to the block, and 1 inch or so of cabinet, you would need 5-6inch screw.
toggle bolts would probably work as well since there is mesh, but i'd be concerned that they might not be able to unfold in that 1-2 inch hollow space. is there absolutely nothing (as in wood studs) in the hollow space?
sevenlol is offline   Reply With Quote
The Following User Says Thank You to sevenlol For This Useful Post:
jaydevries (06-20-2012)
Old 06-20-2012, 10:05 PM   #3
Rewards Points: 89
No sorry, my wall starts with plaster, then mesh, about a 2-3 inch air space, (with spratic studs) then block.
Since plaster can be done several ways I listed the way it's layered from what you would see to the block which is hidden, behind.
I don't think those would hold to the plaster. That's why I ask about toggles and what size to use with 35 inch tall wall cabn.
Old 06-20-2012, 10:22 PM   #4
you would be screwing into the block.
Old 06-20-2012, 10:34 PM   #5
I'm not sure it toggles would work with plaster, never tried.
A safe option would be to figure out where your cabinets will be fastened, cutting out some of the plaster and putting in backing..
Are you sure you can't hit studs where your cabinets are going? The plaster has to be supported by something...
chrisBC is offline   Reply With Quote
Refinishing room-width cuts of plaster walls: will it work? Minich Drywall & Plaster 9 07-19-2011 08:28 PM
kitchen design: should we remove inner wall(s)? ilyaz Kitchen & Bath Remodeling 4 10-26-2010 07:59 AM
Venetian Plaster FYI Plaster Ayn Painting 10 06-30-2010 11:26 PM
diy built-in kitchen cabinets Jeremy Hillary Boob, PhD Carpentry 6 11-29-2008 11:46 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
