Kitchen Cabinets To Metal Studs - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-20-2012, 02:58 PM   #1
Kitchen cabinets to metal studs
I was hired to build a "kitchen" in a commercial type building for photographic purposes. I built a wall off with 2x4 studs at 16"oc. The problem is the other wall in the "L" is block with metalstuds set at 24oc covered with 1/2" drywall. Is there a good way to hang the uppers to the Metal studs or should I just build a "normal" wall to hang from. Thanks for any imput.
antlerdancer is offline   Reply With Quote
Old 02-20-2012, 04:05 PM   #2
Rewards Points: 512
i would have put plywood backerboards before the drywall went up so there was no guessing. now i'd do my best to hang the cabinets off the metal studs, if your that worried put some toggle bolts in.
princelake is offline   Reply With Quote
Old 02-20-2012, 08:58 PM   #3
Pure Genius
Rewards Points: 150
When you say block with metal studs do you mean full studs or hat channel? If hat channel I tapcon through to the block. In all reality you should remove drywall install blocking and install cabinets. It will be behind the cabinets anyways.
Dierte is offline   Reply With Quote
Old 02-20-2012, 09:02 PM   #4
Rewards Points: 582
we pulled down the board in cabinet area..installed wooded braces ..reinstalled board no seams showing.....solid deal did not take long no finish work..ben
Old 02-21-2012, 03:03 PM   #5
Thanks for the suggestions. My main goal was to do as little alterations to the exsisting structures because it is a rented space and I did not want to get involved with the owner. What I did was built a regular stud wall next to exsisting and fastened it to the drywall with toggle bolts and cleats between the studs in several places. I was worried about holding power because of storage in uppers and a micro mounted on said wall. Thanks again. Antlerdancer
The Following User Says Thank You to antlerdancer For This Useful Post:
ben's plumbing (02-21-2012)
What color to paint kitchen cabinets? kimberland30 Interior Decorating 20 11-28-2015 03:33 PM
Vintage metal kitchen cabinets WillK Electrical 4 06-01-2011 11:16 PM
TV Mount on Metal Studs - What hardware is necessary? theproman23 Home Theater 6 03-02-2011 04:28 PM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 01:03 PM
diy built-in kitchen cabinets Jeremy Hillary Boob, PhD Carpentry 6 11-29-2008 11:46 PM
