Kitchen Cabinets And Filler Strips - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-06-2010, 10:51 PM   #1
Kitchen cabinets and filler strips
Getting ready for a new kitchen.The short version company one wants to use 2 24in corners,2 21 in wall,and 1 30 wall in center over microwave.The 2 21 cabinets will have a 3 in filler betwwen it and the corner cabinet.
Second company will use the same size cabinets except for the 2 21s.They will use 2 24s instead.I think the second co. is correct as the cabinets will be much bigger inside and the doors will look better.The cabinets are full overlay doors by Shiloh,co. #1 and Luxor co.#2.Are filler srtips necessary or just a way to sell you smaller cabinets for more money?
nel262 is offline   Reply With Quote
Old 08-07-2010, 05:29 PM   #2
Residential Renovations
Tattoo's Avatar
Filler strips are just that.... FILLER STRIPS.... If the cabinets do not fill the opening then the fillers are used. If you have more room, than install the larger cabinets. Usually the cabinets are being centered over something and the installers are trying to creat a look that will be pleasing to the customer. If you don't want fillers order custom cabinets to size!!
Tattoo is offline   Reply With Quote
Old 08-07-2010, 07:32 PM   #3
These are custom cabinets.The kitchen designer has said the reason for the filler strips is because we are using 4 corner cabinets and the room/walls are not plum/square.Also it prevents the cabinets doors from binding on the side cabinets.Note these cabinets are 24in corners so they will not jut out from the side cabinets.So there is aconcern about the doors hitting the other cabinet when fully open.Kinda of makes sense to me but needed another opinion.Also height wise the cabinets are 36 instead of 39 on an 8 ft tall wall to have room to adjust the crown moulding.Yes???
Old 08-15-2010, 07:01 PM   #4
Old School
cabinetman's Avatar
Countertop height is supposed to be 36". If the cabinets are "custom made", all the details about clearances should be worked out by whoever made the "custom cabinets". Fillers are used by production cabinet manufacturers, and are usually 3". The reason for that is they make cabinet widths usually starting at 9" wide and up, in 3" increments. This is to standardize their so-called "custom cabinets".
cabinetman is offline   Reply With Quote
filler on kitchen cabinet timbo59 Carpentry 7 05-05-2010 09:19 AM
Has Anyone Painted by Hand Over Lacquered Cabinets With Oil? KLR Painting 3 06-21-2009 06:40 PM
restaining kitchen cabinets Gisele Painting 2 07-30-2008 11:40 AM
oil spots(?) bleeding thru paste filler on cabinets 1655graff Painting 1 01-17-2008 09:03 PM
