Kitchen Cab - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-26-2013, 10:37 PM   #1
Rewards Points: 175
Kitchen Cab
I'm installing a laminate countertop. I understand that I can buy a kit to raise it above the cabinets, or just use plywood. I'm going to just use plywood. My question is where do I put the plywood? I understand that I need to put a piece in the both the front and back. How about the middle? In terms of size, should each piece of plywood be about 2-3" wide and the length of the cabinet run?
Thanks for your help,
Richard
RichardZ is offline   Reply With Quote
Old 08-27-2013, 12:24 AM   #2
Rewards Points: 13,468
I just use 1 X 4's, just need to cut to length that way.
Install it all around the edges and the middle.
Make sure to predrill some through holes in the corners for screw to attach the top to.
Old 08-27-2013, 12:58 PM   #3
K&B Designer
Live_Oak's Avatar
Place the buildup strips at the rear of the cabinets next to the wall, and over the cabinet sidewalls perpendicular to the front and rear cabinet walls. You want to distribute the weight evenly over the bases. Depending on who you order the counters from, there may be some buildups already attached, so be sure to dry fit everything first.
Live_Oak is offline   Reply With Quote
My new kitchen needs a facelift (oak cabinets have to stay) EclecticMom Interior Decorating 3 02-12-2012 09:45 PM
Project floor plan for Kitchen and Bath Snav Kitchen & Bath Remodeling 0 01-25-2010 10:51 AM
Kitchen reno, any better suggestions? mgarfield Remodeling 7 01-20-2010 03:37 PM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 08:28 AM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 08:31 PM
