Kerdi Shower System Over Slab - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-15-2010, 12:44 PM   #1
Joe F's Avatar
Rewards Points: 294
Kerdi shower system over slab
I'm remodeling a basement bathroom and would like to use the Kerdi shower set-up. What is the correct way to make the drain connection to my PVC rough in? It appears that I'll need to break up some of the concrete around the drain. Is that the right way to do it?
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 03-15-2010, 10:33 PM   #2
Rewards Points: 5,336
What you do will depend on the base you intend to use. You're not slapping tile on a flat floor.
Ron
Old 03-16-2010, 10:48 AM   #3
Joe F's Avatar
Rewards Points: 294
Ron
No, I'm refering to the kerdi pre-sloped base and curb setup. I'm trying to determine the best way to make the connection between the PVC drain that's included and my rough-in which is in the slab.
Old 03-16-2010, 05:27 PM   #4
I would open the area around the drain as much as needed to set the schluter drain.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Joe F (03-16-2010)
Old 03-16-2010, 05:40 PM   #5
Joe F's Avatar
Rewards Points: 294
Ron
Thought I might have to do that. Thanks.
Old 03-21-2010, 02:44 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The success of the KERDI Shower Kit depends on using the proprietary KERDI Drain. You will need a 2" PVC stub-up to connect to. But you will also have to open the floor about four inches around the drain to accomodate the drain cup that extends below grade with the KERDI Drain.
The hole then will have to be filled with concrete as the floor system is fitted and installed.
XXX
Old 04-06-2010, 09:32 AM   #7
Just call me Andrew
Rewards Points: 1,020
I am also using a schluter shower pan for my bathroom. The pan is not quite as wide as my shower, but I understand I can widen it with mortar. Schluter told me to use "dry pack" mortar to extend the sides of the pan. What is dry pack mortar? Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 04-06-2010, 09:48 AM   #8
DIY staff
Rewards Points: 7,174
Here is a site with the mix and directions--shower pans, shower bases, bathrooms, showers, barrier free, ADA, bathroom remodeling, bathroom renovation
--Mike--
Don't bother hitting this one unless--you are bored.
Old 04-06-2010, 09:51 AM   #9
Just call me Andrew
Originally Posted by oh'mike View Post
I am not seeing it - that site appears to be a competitor of Schluter...I'm missing something.
Andrew
Old 04-06-2010, 09:53 AM   #10
DIY staff
OOPS---Shower Construction Info (a collection of posts) - Ceramic Tile Advice Forums - John Bridge Ceramic Tile
I've saved a lot of shower stuff--hit the wrong button--Mike--
Old 04-06-2010, 09:56 AM   #11
Just call me Andrew
No prob
Andrew
Old 04-06-2010, 11:03 AM   #12
Drypack is a term where you use very little water when you mix the batch. The mix is more "damp" then dry. Just enough moisture so it will clump together.
Ron
Old 04-06-2010, 11:30 AM   #13
Just call me Andrew
Great - I'll probably go with the 5 Sand:1 Mortar mix like described on that site. Thanks a lot!
Andrew
Old 04-06-2010, 05:03 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
For "dry pack"/deck mud...you can use sandmix straight out of the bag. It will be about 3:1 but that's fine in your case. Mix it so that a hand full will clump together like a snowball. Place it around the edges a little above the top of the Schluter slope surface then use a straightegde guided by the surface of the Schluter sloped floor to shave the top of the deck mud. This will maintain the proper slope for you.
XXX
Old 04-07-2010, 06:33 AM   #15
Just call me Andrew
I'll do that, thanks a lot. Why does the guy on that site recommend adding more sand to the premixed stuff?
Andrew
Kerdi shower base Joe F Building & Construction 5 11-04-2009 11:57 AM
kerdi shower base paluch General DIY Discussions 4 09-23-2009 08:08 AM
Shower Pan and concrete slab plumbing LTempleton Kitchen & Bath Remodeling 2 08-08-2009 12:47 PM
I thought I put it back together properly: leaky shower valve (Matco-Norca) shuuy Plumbing 1 06-18-2009 10:44 AM
shower in basement slab philip96 Plumbing 2 06-15-2008 09:46 PM
