Kerdi Curb Question - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-18-2012, 03:50 PM   #1
In a little over my head
Rewards Points: 706
Kerdi curb question
I'm about to start hanging cement board (Permabase?) and Kerdi for a 3x4' shower. Question is: Will a Kerdi Curb (foam) support a frameless glass door with the door hinged on the glass, not hinged on the tile jamb? Or should I build the curb out of 2x4s? The door folks said the glass door would work fine, tho they'll run a header across the top. The bottom hinge attaches to the curb.
Also while we're talkin'; the shower is actually 3x4 with a corner cut off. The door is on the neo corner. Since it's gonna hinge on the glass, the "striker" side of the door meets the tile jamb. Of course, there's no strike plate or stop; the door actually will swing out or into the shower. The tile jamb needs to be purpendicular to the curb/door. How deep would you build the jamb, to make it strong and look right? I'l try to draw a picture, if that doesn't make sense.
Thanks!
ratherbefishing is offline   Reply With Quote
Old 01-18-2012, 10:04 PM   #2
Rewards Points: 706
Here's a picture of the shower. The jamb in question is in red.
Old 01-19-2012, 08:31 PM   #3
DIY staff
Rewards Points: 7,174
I think I may have an answer for you soon----Mike----
Old 01-19-2012, 08:50 PM   #4
mike owes me $53 dollars
Tech Dawg's Avatar
Rbf,
A kerdi curb should be fine, especially since the glass company has to drill into the curb. MAKE sure they fill the hole completely with Kerdi Fix! You can install your curb, upside down so the square holes are facing up and then fill the holes with deck mud for the overkill factor.
As far as your jamb, its all cosmetic and what you would like to see. Looks like your already going to be needing some bullnose trim
Tech Dawg is offline   Reply With Quote
The Following 2 Users Say Thank You to Tech Dawg For This Useful Post:
oh'mike (01-19-2012), ratherbefishing (01-19-2012)
glass tiles over kerdi (thinset question) Queso Bandit Remodeling 12 05-15-2012 03:08 PM
tile pan is flexing - what to do? c2g Tiling, ceramics, marble 34 03-01-2011 04:48 PM
pvc shower pan liner question djrussell Plumbing 2 09-03-2009 02:37 PM
glass tiles over kerdi (thinset question) Queso Bandit Tiling, ceramics, marble 1 04-17-2009 12:39 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
