KCMA Spec For Particle Board - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-06-2013, 05:25 PM   #1
Rewards Points: 199
KCMA spec for particle board
Are all KCMA ( Kitchen Cabinet Makers Association) stamped kitchen cabinets that use particle board construction required to use a 45 psi or higher grade of particle board ?
In other words, on kitchen cabinets that use particle board construction, is 45 psi grade or higher particle board one of the KCMA specifications in order to qualify for their stamp of approval ?
Thanks,
Arky
Arky217 is offline   Reply With Quote
Old 10-24-2013, 08:16 PM   #2
I'm sure the original poster has moved on. But I can say that my company has pretty much moved on from any p.b. other than A-grade. Right now we are in testing to increase our water resistance for kcma. The goal is to have no swelling after 72 hours.
big juicy01 is offline   Reply With Quote
Lennox Furnace with 63K8901 circuit board behaving strangely tgice HVAC 4 06-21-2013 02:03 PM
Foam board over old 4in thick fiber board roofing panels Rebob40 Roofing/Siding 2 03-05-2012 10:24 AM
Fascia board install - unlevel rafter tails giperbolic Roofing/Siding 3 01-18-2012 12:46 AM
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 02:16 PM
How do you ground York furnance control board garryshaf HVAC 11 01-24-2010 01:06 PM
