Installing Walls On Bathroom Remodel - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-30-2012, 02:44 PM   #1
Question
Installing Walls on Bathroom Remodel
3rd floor bedroom, tore down 2 interior walls to expand in 2 directions. Floor is cement.
Should the floor be measured for levelness before beginning to put up new framing for the walls?
doneright232 is offline   Reply With Quote
Old 01-30-2012, 03:06 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Why? Worse case scenario you need to cut the studs different lengths.
titanoman is offline   Reply With Quote
The Following 2 Users Say Thank You to titanoman For This Useful Post:
gregzoll (01-31-2012), woodworkbykirk (01-30-2012)
Old 01-30-2012, 03:25 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,250
yup. just as he said or cut them all the same but go with the shortest length. just use longer nails or screws so teh top plate gets properly fastened to the ceiling. but only if its a partition. if its a bearing wall the studs will have to be precise
woodworkbykirk is offline   Reply With Quote
Old 01-31-2012, 07:11 AM   #4
Contractor
aureliconstruct's Avatar
Yes, it would be much easier to level the floor now rather than later.
aureliconstruct is offline   Reply With Quote
Tags
installing new walls
Help with bathroom remodel!!! jasongilliland Building & Construction 4 11-16-2011 06:05 PM
Bathroom Remodel Questions brucelee Kitchen & Bath Remodeling 15 11-15-2011 08:25 AM
Advice on bathroom remodel jswartsel Remodeling 5 12-07-2010 06:24 PM
Double Bathroom Remodel coreyandnicole Kitchen & Bath Remodeling 1 03-19-2010 09:59 PM
bathroom remodel / need some advice teamcanada1 Kitchen & Bath Remodeling 0 03-06-2010 01:19 PM
