Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 01-12-2011, 07:51 PM   #1
Installing towel hanger shelf through bathroom tile and drywall
Hello All,
I need to install a "towel hanger shelf" for the bathroom. I will need to use some kind of anchor going through tile and then the backing drywall. Can someone recommend type of anchor to use other than a toggle bolt or toggler snaptoggle. I know these would work great, but I`m very concerned about drilling such a large hole through tile. I`ve never drilled through tile before. I`m concerned about cracking the tile. Tips on drilling through tile would also be much appreciated. Thank you very much. Cheers!
zeramuas is offline   Reply With Quote
Old 01-12-2011, 08:47 PM   #2
Super Moderator
Use a 1/4 inch diamond bit--or if it is a soft tile a Bosch carbide bit--then plastic anchors or cedar splits driven into the hole--
a scrap of wood with a 1/4 hole will help keep the bit from skating all over the place when you start the hole-
A little tip on locating your holes--mark the locations on a level first--then transfer the marks to the wall.
Old 01-13-2011, 09:15 PM   #3
Mike,
Are you suggesting the anchor will grap in both tile and drywall or only through the drywall?
Thank you,
Old 01-14-2011, 08:01 AM   #4
Super Moderator
It will grab the tile and the backer board--I usually drill my hole and then whittle a plug out of a cedar shim--then tap that into the hole--Drive screw into wood --
I've seen the plastic ones pop the tile--to hard--no room for expansion.
installing shelving on tile backsplash indignatz Remodeling 7 11-05-2010 07:06 AM
Improving a bad tile to drywall transition navi_jen Drywall & Plaster 5 10-12-2009 09:32 AM
mixing tile and drywall rocketdoctor Drywall & Plaster 1 10-09-2009 01:17 PM
Replacing a few individual tiles in bathroom - chiseled a bit into the drywall Pickngrin Drywall & Plaster 4 12-28-2008 07:40 PM
Bathroom tile disaster blonde princess Building & Construction 3 09-29-2008 06:19 PM
