-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   Installing towel hanger shelf through bathroom tile and drywall (http://www.diychatroom.com/f80/installing-towel-hanger-shelf-through-bathroom-tile-drywall-92117/)
zeramuas 01-12-2011 07:51 PM
Hello All,
I need to install a "towel hanger shelf" for the bathroom. I will need to use some kind of anchor going through tile and then the backing drywall. Can someone recommend type of anchor to use other than a toggle bolt or toggler snaptoggle. I know these would work great, but I`m very concerned about drilling such a large hole through tile. I`ve never drilled through tile before. I`m concerned about cracking the tile. Tips on drilling through tile would also be much appreciated. Thank you very much. Cheers!
oh'mike 01-12-2011 08:47 PM
Use a 1/4 inch diamond bit--or if it is a soft tile a Bosch carbide bit--then plastic anchors or cedar splits driven into the hole--
a scrap of wood with a 1/4 hole will help keep the bit from skating all over the place when you start the hole-
A little tip on locating your holes--mark the locations on a level first--then transfer the marks to the wall.
zeramuas 01-13-2011 09:15 PM
Mike,
Are you suggesting the anchor will grap in both tile and drywall or only through the drywall?
Thank you,
oh'mike 01-14-2011 08:01 AM
It will grab the tile and the backer board--I usually drill my hole and then whittle a plug out of a cedar shim--then tap that into the hole--Drive screw into wood --
I've seen the plastic ones pop the tile--to hard--no room for expansion.
