Installing A Toilet Over A New Ceramic Floor - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-29-2011, 05:05 PM   #1
Installing a toilet over a new ceramic floor
We just had a new ceramic floor put in our bathroom and also had a new toilet installed. I notice that the toilet moves left and right on the floor (sideways, not rocking). Is there a special way of installing so that the toilet doesn't move? I'm affraid of leaks!
Kazhow is offline   Reply With Quote
Old 06-29-2011, 05:29 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Probably not enough seal in the fit-up joint, especially now.
Could also probably tighten the bolts a little more. Those pedestals can break under too much strain from a mounting bolt so be careful there. The seal should be checked for sure now and replaced. There is more than one thickness of seals and they can be stacked if necessary.
Toilet pedestals can also be caulked to the floor if necessary and that will help to stop movement but replace the seal first in this case. If you should caulk it, leave the backside of the pedestal un-caulked so any seal leaks can be detected.
XXX
Old 06-30-2011, 06:13 PM   #3
Rewards Points: 5,336
The "special way" is installing the toilet correctly. A rocking toilet puts stress on the ceramic material around the bolts.
As Bud said, check the bolts so they are appropriately tightened. If you tighten them too much, you'll crack the ceramic.
If the bolts are tight and the toilet is level and still rocks, you can install composite shims to stop the movement. You slide them under the edge and gently tap them in place. You then cut off the excess. Caulk around the front and sides, but leave the back uncaulked.
You should be good.
Ron
B. Franklin 1759
Old 06-30-2011, 08:17 PM   #4
DIY staff
Rewards Points: 7,174
Like Bud mentioned---once a toilet has moved the wax seal is ruined--they are not self repairing--so change it!
adding a 2nd floor toilet dreamerdiy Kitchen & Bath Remodeling 1 02-02-2011 03:51 PM
Installing ceramic tile on garage concrete floor erotavlas Flooring 11 02-27-2010 11:01 PM
Installing toilet on concrete floor diymaniac Plumbing 2 12-14-2009 10:52 AM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 06:19 AM
