Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 05-06-2012, 07:47 PM   #1
Installing sliding shower doors on a bath tub
Hi there,
Just wondering how I lay the base track for shower sliding doors on the edge of a tub that's curved? All the tips I have read or viewed all show them installing the bottom track on a flat tiled surface for walk in showers so just wondering solutions to install that bottom track on the curved edge of a bath tub.
Thanks a lot
Bweatherbee is offline   Reply With Quote
Old 05-06-2012, 08:41 PM   #2
Without a picture it's hard to say.
No way to install a straight bottom rail on a curved tub if it's curved enough that the rail hangs over the front or back of the tub.
Old 05-28-2012, 10:35 PM   #3
Notice your post is a few weeks old so you probably are past the need for help, but just in case:
Assuming the tub is made of a material you can drill or screw or drill & tap into, I'd buy a piece of aluminum shaped like [__] and face it down onto the tub rail, giving you a flat rail/floor to mount on. Put caulk under it, and screw the door rail to and through the thing.
bareshiyth is offline   Reply With Quote
Relacing a shower with a half bath seth Building & Construction 9 11-22-2011 11:58 AM
installing shower doors cfio Remodeling 1 10-17-2010 07:13 PM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Adding a shower to a 1/2 bath amyjean Plumbing 1 09-10-2005 08:06 PM
