Installing OTS Microwave - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 08:57 PM   #1
Hey so I'm installing an over-the-stove microwave and I have backsplash that prevents the microwave backing frame from sitting flush on the wall. My question is...
1. Should I remove all of the backsplash that would sit behind the microwave?
2. Should I cut 2 six inch pieces from the existing backsplash and put them in both corners so that the backing frame sits flush?
3. Just place a bolt behind the backing frame so that it will act as the filler between the wall and frame?
The image below illustrates #1 and #2. The yellow box is #1, the red boxes are #2.
Sketch is offline   Reply With Quote
Old 05-27-2012, 09:20 PM   #2
Rewards Points: 13,274
Anything the same thickness as the back splash that can be drilled will work fine, plywood, piece of trim, whatever.
I would not cut out the back splash that's already installed.
Old 05-27-2012, 09:25 PM   #3
Thanks. I was thinking the same thing as well since I saw some plywood at home depot.
over-the-range microwave problem aumanpj Appliances 6 12-04-2010 06:46 PM
Installing new over the range microwave islic Appliances 3 05-03-2010 07:39 AM
Microwave ground prong sparks/melts upon plugging it in microwaveman Electrical 30 05-10-2009 11:30 PM
Installing over the range microwave ex-Khobar Andy Electrical 1 02-06-2009 04:20 AM
Installing an over-range microwave onto brick backsplash passportsf General DIY Discussions 3 02-03-2008 12:46 AM
