-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   Installing OTS Microwave (http://www.diychatroom.com/f80/installing-ots-microwave-145057/)
Sketch 05-27-2012 07:57 PM
1 Attachment(s)
Hey so I'm installing an over-the-stove microwave and I have backsplash that prevents the microwave backing frame from sitting flush on the wall. My question is...
1. Should I remove all of the backsplash that would sit behind the microwave?
2. Should I cut 2 six inch pieces from the existing backsplash and put them in both corners so that the backing frame sits flush?
3. Just place a bolt behind the backing frame so that it will act as the filler between the wall and frame?
The image below illustrates #1 and #2. The yellow box is #1, the red boxes are #2.
http://imageshack.us/photo/my-images...acksplash.png/
joecaption 05-27-2012 08:20 PM
Anything the same thickness as the back splash that can be drilled will work fine, plywood, piece of trim, whatever.
I would not cut out the back splash that's already installed.
Sketch 05-27-2012 08:25 PM
Thanks. I was thinking the same thing as well since I saw some plywood at home depot.
