Installing Laminate Counter Cap Without Offset Router? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-30-2013, 09:00 AM   #1
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
Installing laminate counter cap without offset router?
Here is my dilema. I have the countertop installed, and need to attach the cap to the unfinished edge. No problem. However, I don't have an offset router to trim the edge near the wall, and obviously my full-sized router is too big to get close and trim it up. I know I can just use a file, but the cap is way oversized compared to where it needs to fit and I'm worried about the file doing damage.
What is the suggested way to go about doing this, without making a mess of the whole thing?
Here's a picture.
Thanks.
hyunelan2 is offline   Reply With Quote
Old 07-30-2013, 10:27 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 390
What I have done in this situation is use a piece of hpl or something thin as a gauge or spacer, lay the piece of hpl on the back of the cap (butt the back of the cap) and use a scoring tool and score from the back side where you can't use your router. Score very deep as you will be breaking the hpl and the deeper the score the cleaner it will break. By scoring the back with the scoring tool on the piece of hpl, it will give you enough that you will still have to file but it won't be as hard to mess up. I hope this is clear enough, if not just post and let us know.
One more thing, you will have to hold the cap on as you use the scoring tool as you will be exerting pressure from behind which could cause the cap to come loose.
OK one more thing, I usually will tape the spacer to the scoring tool instead of trying to hold it in place.
Just had another thought, you could use a belt sander and sand as close as possible but be very careful not to build up heat or get too close to the finish hpl, once it is ruined, it is ruined.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 07-30-2013, 03:14 PM   #3
Rewards Points: 81
Looks as if you have already applied the end cap to the counter? If you haven't, take a pencil and while holding it against the counter, trace the outside edge onto the end cap. Then tape the end cap with painters tape and trim near the marked line using a dremel or similar tool. Now when you apply the end cap there isn't as much to file off.
MaineLL is offline   Reply With Quote
Old 07-30-2013, 04:10 PM   #4
hyunelan2's Avatar
Rewards Points: 692
No, it's not attached, I was just holding it there for the picture.
Thanks for the tips guys.
Old 08-31-2013, 05:12 PM   #5
Rewards Points: 13,712
Need a trim router not an offset router.
If it's not even attached then I'm not seeing the issue.
Just side it out and over and trim it.
Laminate counter tops, can they be joined? Strife_Design Kitchen & Bath Remodeling 6 07-05-2013 11:12 AM
cutting laminate counter top brizzle Carpentry 5 03-30-2013 09:20 PM
installing laminate flooring ? jjchips Interior Decorating 2 03-12-2013 09:01 PM
Installing Laminate Flooring over Wood Laminate Floor bantammom Flooring 7 05-27-2011 03:34 PM
Floor spacers when installing laminate floor flybynite Flooring 4 12-04-2006 09:24 PM
