Installing Kitchen Upper Cabinets, My Soffiet Is Level, Gain 1 Inch Over 15 Feet - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-25-2012, 07:22 PM   #1
Installing kitchen upper cabinets, my soffiet is level, gain 1 inch over 15 feet
What can I do to install my upper kitcher cabinets when my soffiet is not level. I gain 1" over 15 "?
Skip19 is offline   Reply With Quote
Old 09-25-2012, 07:35 PM   #2
I am not sure what you mean by 1" over 15" but I had a similar problem and solved it by installing a 1x4 as a backing for the crown and on top, installing a crown molding.
Because the backing and crown molding were in same color, a slight uneveness was not noticeable.
Good luck
allthumbsdiy is offline   Reply With Quote
Old 09-25-2012, 07:38 PM   #3
Rewards Points: 13,732
Post a picture.
Old 09-25-2012, 10:25 PM   #4
Rewards Points: 83
Your soffit is off by 1" in 15 feet....sounds about right for today's construction.
i imagine you wish to put the cabinets flush with the soffit?
What if you had the cabinets stick out farther than the soffit by 6" and lower thqn the soffit by 6" as well, and then install a crown molding at the top edge of the cabinet that would cover the soffit edge?
Just a thought without a picture. If you can cover up the view of the unlevel soffit that would help. Is the rest of the ceiling level?
D270 is offline   Reply With Quote
Old 09-25-2012, 11:16 PM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Skip, Welcome to the Forum
Here is how to Post pictures in the How To section,
To add your location to your profile see more How-To
Disclaimer
& Stay Safe
.....Bob Lavery
Installing Cabinets In Un-level Kitchen whiskeykid Carpentry 14 01-31-2009 07:43 AM
Installing receptacles in kitchen base cabinets shtoink Electrical 13 10-15-2008 07:52 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
Installing Kitchen cabinets help helpless handyman Carpentry 16 07-07-2007 06:12 AM
installing kitchen cabinets ncoppola09 Carpentry 9 01-06-2007 09:07 PM
