#1 |
installing granite counter
I am redoing my bathroom and it seems like everyday something else gets added! I'm thinking about using my base cabinet and getting a granite counter top to go over it. The cabinet is only about 24" by 30". What would I need to do to put granite on it? Do I need to add some support or is the base cabinet enough for this small granite? Also do I just silicone the top down?
I haven't called any granite places yet about this but can they make the top and I install it? Also how do you scribe it to the walls or would I just caulk? Sorry for so many questions but just want to learn a little before I call the granite place. Thanks |
#2 | |
K&B Remodeler/Tile Guy
installing granite counterQuote:
Yes, you just use silicone to attach the top to the cabinet. Yes, you can go to a local stone supplier and have them cut a square piece of granite (24" x 30") and the appropriate back splash. If the vanity is tucked into a corner, you'd get 2 splashes. I cannot imagine your wall will be that out of square. You can check by using a framing square to see. Normally, I just have them cut the top and I install. Silicone the top to the cabinet, silicone the splashes to the wall. I actually do exactly what you're suggesting all the time. As a matter of fact, I'm installing a granite vanity top tomorrow for a customer. My 22" x 22" top cost me under $300, including the undermount sink. Look for remnants at the stone supplier. They are extra pieces they have laying around.
Angus To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Thanks angus. It is in the corner so I should be fine.
| Display Modes | |
| Stonemark & Silestone Countertops......??? | DepotDweller | Remodeling | 9 | 06-25-2009 12:44 PM |
| Installing a Granite counter top | DaleB | General Discussion | 2 | 03-13-2008 08:10 AM |
| installing granite counter tops | dnassif | Remodeling | 4 | 07-01-2006 09:37 AM |
