-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   installing granite counter (http://www.diychatroom.com/f80/installing-granite-counter-37563/)
ponch37300 02-03-2009 08:39 PM
I am redoing my bathroom and it seems like everyday something else gets added! I'm thinking about using my base cabinet and getting a granite counter top to go over it. The cabinet is only about 24" by 30". What would I need to do to put granite on it? Do I need to add some support or is the base cabinet enough for this small granite? Also do I just silicone the top down?
I haven't called any granite places yet about this but can they make the top and I install it? Also how do you scribe it to the walls or would I just caulk? Sorry for so many questions but just want to learn a little before I call the granite place. Thanks
angus242 02-03-2009 10:44 PM
While granite is heavy, a piece that size will not need any additional support.
Yes, you just use silicone to attach the top to the cabinet.
Yes, you can go to a local stone supplier and have them cut a square piece of granite (24" x 30") and the appropriate back splash. If the vanity is tucked into a corner, you'd get 2 splashes. I cannot imagine your wall will be that out of square. You can check by using a framing square to see. Normally, I just have them cut the top and I install. Silicone the top to the cabinet, silicone the splashes to the wall.
I actually do exactly what you're suggesting all the time. As a matter of fact, I'm installing a granite vanity top tomorrow for a customer. My 22" x 22" top cost me under $300, including the undermount sink. Look for remnants at the stone supplier. They are extra pieces they have laying around.
ponch37300 02-04-2009 12:10 AM
Thanks angus. It is in the corner so I should be fine.
