Installing countertops in a kitchen which is not square.
Hello,
I am working on a very old farmhouse in which none of the walls are really square. I have a plan for an L-shape kitchen, and the wall which will have the corner of the L is about 95deg, so quite a bit off square.
The budget is low-end, with plans to use pre-fab countertop without the 45deg angle cuts. The countertop will not have an integrated backsplash, but rather we will tile one afterwards.
I don't think I have the tools or the skill to make two 47.5deg cuts and get it to really look nice. But I think I could get it fairly close. Is there any product which could be made to fill any 2-3mm gaps which I expect if I go this route?
I'm also open to any other suggestions on a better way to do this? I have considered running 2 straight pieces and having the join run parallel with the longer piece, thus meaning that I'd just have to make one 5deg cut along the side of the shorter piece, however, I think that would not look good with regards to the bullnose along the front of the countertop.
Open to any suggestions.
PS. As far as I have seen, I have not found countertop for sale with the 45deg cuts on the end (I am in France), as if I did, I toyed with the idea of using this and just filling in the rear edge along the short wall.
-Rick
