Installing Countertop With Crooked Wall - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-21-2011, 07:28 PM   #1
installing countertop with crooked wall
I am installing a new bathroom countertop and I have discovered that the back wall has uneven places in it. Is there a good method of hiding these places? I suppose that caulk is the obvious method, but is there a trick to caulking which will not show? Thanks. Gary S.
Gary S is offline   Reply With Quote
Old 10-22-2011, 01:26 AM   #2
Military Mom of 4
Snav's Avatar
If it's not to much space - I'd forgo the caulk and cut some nice trim to go around it. Looks nicer - people will think it's for aesthetics and not filler.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 10-22-2011, 03:38 AM   #3
depending on how bad it is, and what product your countertop is, you can scribe the countertop to the wall then use a beltsander to shape it. Different methods for different materials. Another thing you can do is carve out the drywall in the "high" area, cut it out so the countertop fits, use a knife and cut along with the countertop in place, so you will only cut out that area, and won't have to repair the wall.
Once you get it pretty close run a thin bead of caulk to finish it off, smooth it off with your finger.
chrisBC is offline   Reply With Quote
The Following User Says Thank You to chrisBC For This Useful Post:
Ron6519 (10-23-2011)
Installing exterior door on crooked wall ihoven Carpentry 1 08-13-2011 11:59 PM
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 02:55 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Installing New Wires In Wall? madcitysw Electrical 5 01-14-2008 09:08 PM
Help Me.....installing Wall Safe shaw Carpentry 7 10-01-2006 05:50 PM
