Installing Bathtub On Top Of Tile - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-12-2011, 08:06 AM   #1
Installing bathtub on top of tile
We are installing a bathtub with an apron and I would like to tile the floor under the tub.
The old tub sat on the 1/2" subfloor then the floor and underlayment were added.
I would like to fill in the missing 3/4" plywood add the underlayment then tile the entire floor then install the tub. I wouldn't necessarily need to tile all the way under the tub just get it a few inches past the apron.
I don't see any problem with this as long as the supports under the tub are not sitting on part of a tile. Also he hardibacker will mortared to the floor and screwed and every 6 inches.
Does this sound ok?
tvanharp is offline   Reply With Quote
Old 03-12-2011, 08:37 AM   #2
DIY staff
Rewards Points: 7,174
Bad plan usually--Most floors are not level--so one end of the tub is up a bit off the floor--
The backer and tile will hide that---the thinset used to set the backer acts as a grout to support the tub lip.
Is there a good reason you want to install the tub in this way?
Old 03-12-2011, 09:24 AM   #3
I would like more support under the tub, don't want to cut the tile to match the apron curves, and would like to prevent water from penetrating once the caulk starts to crack.
Old 03-12-2011, 01:22 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
This is an acrylic tub ????
Typically those things are notorious for coming to you tweaked in some fashion. They are never perfect. I personally think they should be installed over a suitable subfloor so that they can be adjusted as needed.
In most of the cases I'm familiar with the "apron" is somewhat adjustable so that one can install tile and its related backer so as to cross over the line of the bottom of the apron but not go completely under the entire tub. This way: No one knows (or cares) that the tile isn't under the tub.
Tile being under the tub WILL NOT offer any additional support under the tub, it will only add weight to the structure.
Once the caulk does crack (if it does) this is a maintenance issue, which it is anyway.
XXX
Old 03-13-2011, 05:21 PM   #5
Rewards Points: 5,336
Whether you put the tub on the tile or next to the tile, you'll still need to caulk the interface. Use a good quality silicone caulk and it will be a long, long time before you need to do it again.
The curved part can be tricky, but using a grinder as a shaper, you can get very good results. Just takes a little practice.
Ron
Old 03-14-2011, 07:42 AM   #6
Thanks for the suggestions, I do plan on running the tile under the tub. We picked up the tub this weekend and it looks that will work good, I'll just need to be sure to keep the tile level under the apron and carefully shim where the 5 tub feet are located.
I'll post back with the results.
Old 03-14-2011, 08:13 AM   #7
DIY staff
Steel or aluminum roofing tins make good shims---sold in packs of 10---Mike---Good luck and have fun
Old 03-14-2011, 08:43 AM   #8
They also now sell composite shims.
Ron
Installing Stone Veneer Over Tile (see pic) bpdavis0 Tiling, ceramics, marble 10 05-29-2012 09:06 AM
Installing floor tile but don't want grout gap to turn black overtime gatorade Flooring 4 02-07-2011 12:13 AM
No Tile around the bathtub, what can I use? Ziggi Kitchen & Bath Remodeling 3 12-22-2010 11:08 PM
Installing porcelin tile issue of clearnace and underlayment jchristopher553 Tiling, ceramics, marble 1 11-03-2010 04:28 PM
Installing pre-hung door over tile to laminate transition aldgagnon Carpentry 5 10-26-2010 06:37 PM
