Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 06-13-2012, 07:33 AM   #1
install kitchen island Kraftmaid cabinets
What are the instructions for:
1. Connecting the base units to each other
2. Securing the island to ceramic tile floor; and is this necessary since the countertop will be granite (very heavy)
3. Attaching decorative end panels
Thanks so much!
Lisa
turnstep is offline   Reply With Quote
Old 06-13-2012, 07:51 AM   #2
Stay-at-home GC
The units will get screwed together through the face frames and bolts through the bases.
If the Tile is not in you could shim the entire island on a piece of plywood and screw to that.
If it is I would drill through the tile and screw a wood L bracket through to the subfloor and then screw your bases to the L bracket.
Decorative end panels get attached by screwing from inside the box of the cabinet into the back of the panel, effectively "pulling" the panel tight to the cabinet. Be sure and use the correct length screw and avoid over-driving and blowing out the face of the panel.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Staining Help Needed! I finished my Red Oak Kitchen Cabinets and they look horrible!! mojavekat Painting 14 04-10-2013 07:39 PM
Leveling Kitchen Cabinets for Granite - how level?? vsheetz Kitchen & Bath Remodeling 13 03-02-2012 08:54 PM
ceiling/wall slanting over kitchen cabinets fdf Remodeling 8 02-26-2012 03:52 PM
KraftMaid cabinets BlueBSH Building & Construction 8 09-27-2010 09:51 PM
lay travertine floor or install kitchen cabinets first? palacenil Flooring 31 07-28-2010 11:42 PM
