Inside Corner For Tin Backsplash - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-09-2011, 08:59 AM   #1
Inside corner for tin backsplash
How do you do an inside corner piece of tin? Just bend it as square as you can or cut it at the corner or is there a better way?
hcdouglas5 is offline   Reply With Quote
Old 08-10-2011, 09:59 AM   #2
Rewards Points: 5,336
Bending it makes more sense then a seam in the corner. But can you bend it without distorting the design?
They also make a crown type molding for tin ceilings. Basically a corner piece to hide the edges. Whether you have that available and it's worth the extra cost is another thing.
Ron
B. Franklin 1759
inside corner gap brianford Drywall & Plaster 1 04-22-2011 09:50 PM
Replacing 3-stud Corner and Bottom Sill (56k Beware) TellyDSP Building & Construction 3 03-13-2011 06:28 PM
Framing Support for Inside Corner on L-Shaped Stairwell jsoares4 Carpentry 5 01-24-2011 07:25 AM
Left or right hand crown inside corner? Klawman Carpentry 9 01-08-2010 03:19 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
