Ideas On Moving A Bath Tub Drain For New Tub - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-01-2014, 09:13 PM   #1
Ideas on moving a bath Tub drain for new tub
I have a new problem with installation of new tub - the drain & overflow need to be moved approximately 1-inch over to match the new tub installation
Is there a semi-simple way to do this?
What are some options?
It is on the second floor of house and has wood sub-floor
oiler39 is offline   Reply With Quote
Old 05-01-2014, 09:21 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,790
Cut and adjust yout ABS/PVC an inch over.
MTN REMODEL LLC is offline   Reply With Quote
Old 05-02-2014, 05:08 PM   #3
MTN - don't totally understand your response
My drain is more than likely original w/ house (50 years old) it's not ABS / PVC and had planned to use a new brass drain and overflow unit to replace existing
Old 05-02-2014, 05:16 PM   #4
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,636
I believe what he meant was the simplest way is to start cutting your pipes to relocate them to where your drain on the new tub is.
No simple way other than finding a tub with the holes in the exact same place which is not likely to happen.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
The Following User Says Thank You to 123pugsy For This Useful Post:
MTN REMODEL LLC (05-02-2014)
Old 05-02-2014, 07:09 PM   #5
Oiler.... As Pugsy explained/said.... all you can do is relocate your drainage.... ASSUMING you can't relocate the tub....
But, there is no magic trick per se to make water jump an inch unless it is in pipe......
If you can tell everyone 1) What you have (like type existing pipe, slab or any access to the tub plumbing 2) what you want to do.... all specifically with dimensions, maybe pictures.....
alot of experienced and creative guys here that will try to give you their best ideas....
I think there was little response, because basically there was no information...
Best
Old 05-02-2014, 07:18 PM   #6
Rewards Points: 582
I would cut back on the pipe to drain side then off set with 22 1/2 s.. a picture of what you have will let me tell you what connectors you need..
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 05-02-2014, 07:24 PM   #7
SEE.....
Old 05-10-2014, 07:30 AM   #8
I have taken advice and am in process of moving drain
I will attempt to get photos attached and additional information soon for more assistance
NEW question is that I purchased a new tub and drain assembly but have not seen a gasket included - question is it standard to have a gasket on the underside of tub where the bath drain and the floor drain are connected??
Old 05-10-2014, 08:13 AM   #9
never mind on last question - I reviewed instructions and there is a gasket showing to be installed however I do not see one in box of parts do you think I can find a comparable gasket at big box store?
Old 05-10-2014, 03:02 PM   #10
123pugsy's Avatar
Look again. They have a way of actually being there between parts and are often just overlooked. I would imagine the box stores would have them. If not, they'll try to make you buy a whole new drain.
bath tub drain leak amakarevic Plumbing 12 12-05-2011 06:57 PM
Bath tub Drain problem Timmay Plumbing 6 03-01-2010 04:50 PM
Bath tub Drain not stopping water 100% to fill tub superdairyboy Plumbing 5 02-13-2010 10:53 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Old Type Bath Drain Tool Junkie Plumbing 4 09-26-2007 03:05 PM
