I Screwed In My Whirlpool Bathtub To Studs??? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-26-2010, 08:33 PM   #1
I screwed in my whirlpool bathtub to studs???
I got a whirlpool bath tub and I am putting tile above it. I drilled into the top of the tub and then nailed it in with roofing nails. Then I read the directions and see that the nails should be above the flange that I drilled and nailed. They advise against drilling into the flange and mounting it. What is the problem with drilling and nailing the tub flange to the wall studs?
rgall is offline   Reply With Quote
Old 11-26-2010, 08:52 PM   #2
Ultimatetouch
Typically you pin a nail/screw so that it rests on the top of the flange holding in place by friction more or less not nailing through the flange. I would do like your supposed to do and calk those holes you made. The reason is most likely to get the fastener further away from water, not making a hole, and not risking the tub settling or cracking from you puting a hole in it.
__________________________
Ultimatetouch
Kitchen Remodeling Chicago, Bathroom Remodeling by an Illinois Remodeling Company
ultimatetouch is offline   Reply With Quote
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 12:04 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 01:25 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 04:16 PM
why use roofing nail to attach a bathtub to studs ? amakarevic Building & Construction 2 06-24-2008 12:05 PM
