Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 01-25-2013, 02:28 AM   #1
I need to put vinyle tile on my wall but i cant because the wall is a mess
I took down old tile off the wall and now it is so rough with the clue or
whatever they put it up with I cant get it off . How do I FIX MY WALL.
TLM L HEM is offline   Reply With Quote
Old 01-25-2013, 10:30 AM   #2
"You can do anything"-Mom
brockmiera's Avatar
That depends. What was the wall made of? I'm assuming drywall since you pulled some off. A picture really does help. If it is just drywall and it is in an area that isn't exposed to water then a top coat of drywall compound should work fine. I'm not sure if that is exactly what it is called but I'm sure some drywall experts will be along to correct me.
Please post a picture when you can though.
brockmiera is offline   Reply With Quote
The Following User Says Thank You to brockmiera For This Useful Post:
BigJim (01-25-2013)
Old 01-25-2013, 01:28 PM   #3
May be faster and less dust to just remove it and replace with new drywall fo a perfectly flat surface.
Dry Wall Over Tile? Francik Drywall & Plaster 3 12-19-2012 08:30 PM
How to make wall smooth after removing tile? cheapchick Remodeling 20 04-09-2012 02:59 PM
unlevel floor and diff. thickness wall tile bryan1282 Tiling, ceramics, marble 2 08-08-2011 10:26 AM
Full wall of tile over drywall eend Drywall & Plaster 1 07-24-2011 06:30 AM
Bathroom wall tile Ricksweares Flooring 10 02-26-2008 04:16 PM
