Huge Hole Behind Sink How To Cover? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-06-2012, 10:33 AM   #1
Huge hole behind sink how to cover?
I was just trying to switch out a large vanity and was surprised by this. Should I try to patch and cover all of this? What is the best way to go about this is there any possible reason this was left open?
CXmandering is offline   Reply With Quote
Old 03-06-2012, 10:45 AM   #2
Rewards Points: 13,296
If that area is just a knee wall in the middle of the room and not an outside wall then it's your choise to cover the hole or not.
You would have to just mark out a section needing to be replaced with some straight lines and cut the vertical lines along the sides of the studs so you miss the nails, or remove the screws or nails. If you cut along the sides of the studs simply install some new ones along side of the ones that are there now to have something to attach your patch to.
Old 03-06-2012, 12:51 PM   #3
Rewards Points: 1,092
"...is there any possible reason this was left open?" Either laziness or fear of having to dig back in there later come to mind.
Old 03-06-2012, 03:56 PM   #4
Rewards Points: 52
This was the first thing that came to my mind as well, so I would definitely look everything over, real close, as they may have done something that they weren't sure would hold up. After that, as Joe said, it's your call, but I would take the piece of plywood out and drywall it, if only just because.
Old 03-06-2012, 04:09 PM   #5
Love for Construction
<*(((><'s Avatar
I don't think it's a knee wall looks like a mirror above...optical illusion. I would take off the plywood, find studs on each side of the opening and remove the drywall in between but make the cuts of the center of the studs so you are able to secure the existing and new drywall. Then i would tape and mud it real quick, it doesn't have to look pretty I it's going behind the cabinet.
-luke-
<*(((>< is offline   Reply With Quote
Old 03-07-2012, 07:50 PM   #6
Thanks for all the replies. I was nervous since I watched several replacing vanities videos and nobody encountered this. Turns out what looks like plywood in the picture was actually yellowed, stained, drywall. Following suggestings I cut out and rescrewed in new drywall in the big hole and plastered up everything except the small slat between the two pipes coming out. I'm hoping to paint it on Friday.
-Cindy
Advice on Replacing Rusted Bath Undermount Style Sink mdonovan Plumbing 12 11-09-2013 03:36 PM
Ceiling light fixture does not cover hole Elkypro General DIY Discussions 11 12-27-2011 09:29 AM
How to cover a hole in a floor slab tomseeley Flooring 2 11-16-2009 01:14 PM
Can I cover this hole with insulation? [pics] Brandon19 HVAC 5 10-08-2009 10:47 PM
Sink hole under garage slab. diggitydog Building & Construction 3 08-31-2006 01:49 PM
