How To Tile Around Tub With No Lip - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-14-2009, 11:43 AM   #1
how to tile around tub with no lip
I have an old house with a bathroom where I just tore down the shower/tub surround walls. It previously had plastic tiles with drywall. It's now torn down to the framing.
I see now the tub has no lip, but I was planning on tiling the walls, using cement board. Can I still do that and if so, what do I do with the area between the tub and the wall where the lip would normally be on all 3 sides?
ksera123 is offline   Reply With Quote
Old 03-23-2009, 06:09 AM   #2
That must be a very old tub, why not replace it while everthing is torn out?? Otherwise, start your tile with a minimum gap at the tub and be very careful about keeping it caulked.
Old 03-23-2009, 06:56 AM   #3
Remodeling Contractor
leave the CBU up about 3/8" Leave the tile up about 1/4" Install a backer rod to fill the void and caulk.
The Following User Says Thank You to Bob Mariani For This Useful Post:
Rockprof (12-14-2012)
Old 03-23-2009, 10:17 PM   #4
tiling a tub w no lip
I did consider getting a new tub, but this old ceramic one is in really good shape and it's deep- better than a lot of those newer plastic types. Plus I'm trying to keep the old budget down.
Anyway, this backer rod just gets 'stuffed' into the space between the bottom of the cement board and the top of the tub? Do you do anything else to install it? Lastly, then you just caulk around to cover the b rod?
It looks also like there are different types of backer rod. Do you have a recommendation?
Sorry, I'm far from a pro, so just learning. Thanks for your help
Old 03-24-2009, 06:16 AM   #5
Buy from a tile or mason yard. Not sure what you are seeing when you say there are many types. Many sizes yes. The reason is that a caulked joint must be sufficient size to allow the caulk to flex, yet small enough to not break the bond. And a joint should always have two and only two points of bonding. (it will not bond to the foam rod.) Leave a 1/4" gap, push in a 1/4" backer rod with a putty knife back a 3/16" and caulk. Be sure to clean the area with denatured alcohol first. Caulked joint must be tooled. Use the back of a old spoon for this.
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
