Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 10-15-2011, 02:51 PM   #16
How to remove outlet from tiled wall, then patch drywall and retile?
Originally Posted by Bud Cline View Post
That's correct! I said that because turning what was once a "switch leg" into and "outlet" wouldn't be all that easy to do for for a novice.
My thinking is...the wires used for the switch would have to be abandoned to make room for the arrival of new conductors for an outlet. How? Just shove them into the stud cavity? Then new conductors would have to be fished into the existing box. I see a very small wall area between two counter tops. This wall area is already tiled and could interfere with the fishing of additional conductors. I suppose it would be do-able if a person had the necessarily level of knowledge in the matter.
In the meantime, put a blank plate on it and move on.
I saw a remodel box used for the switch and an outlet 4" away. The tabs are released and the box pops out, if needed, but I don't think it will be. The feed for the switch would probably be from the outlet. They cap the outgoing wire to the light and install an outlet. If there's only a switch leg there(no neutral), they cap it and run a feed from the outlet. With the box out of the wall, real easy as you can see the box next to it as it's 4" away.
Code wise, I don't know if you capped the switchleg from the light(if that was the way it was wired), you would be able to cover the dead wire with tile. It would be an inelegant solution in either case.
Ron
B. Franklin 1759
Old 10-15-2011, 03:53 PM   #17
Moderator
I'd patch the drywall before replacing all the tile. They downgrade the counter-top.
Gary
Clothes taking longer to dry?
Old 10-15-2011, 05:02 PM   #18
Msradell's Avatar
Originally Posted by Clutchcargo View Post
You cannot bury a live junction box. It's against code. I'd either coverplate it or do add an outlet.
They already said the wires would be abandoned and disconnected on both ends which would mean they could be buried! They would just have to make sure that somebody wouldn't attach to them in the future.
Msradell is offline   Reply With Quote
Old 10-15-2011, 05:05 PM   #19
Tileguy
Bud Cline's Avatar
Thank you.
Decided to remove grout and re-do PatrickGSR94 Tiling, ceramics, marble 3 03-22-2012 12:12 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
How To Support A Drywall Patch For Hole In The Wall? dsq Drywall & Plaster 7 02-23-2009 03:48 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
