How To Remove Old Grout. - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 07:57 AM   #1
Rewards Points: 103
How to remove old grout.
Hello,
What is the best way to remove old grout? Is there any grout softener available on the market?
Thanks.
sukhenkoi is offline   Reply With Quote
Old 03-01-2012, 10:36 AM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
A good old fashioned grout saw is one way to remove it. Available at tile stores, or event the big box stores.
There are also power tools that can be used. Dremel makes a grout attachment. Just be careful if you go this route, it's easy to damage the tiles.
I don't know of any softener to help remove it, but there are grout stains if your only issue is the color.
It's a very tedious and time consuming job. Why do you want to remove it?
The Following User Says Thank You to Blondesense For This Useful Post:
sukhenkoi (03-02-2012)
Old 03-01-2012, 10:46 AM   #3
Rewards Points: 13,960
I use one of these with a diamand blade. It will make the job super easy to do.
https://www.rockwelltools.com/US/Sonicrafter-P1353.aspx
There's lots of companys that sell this style tool. Northern Tools has a cheaper version.
This one tool has hundreds of uses.
Old 03-02-2012, 06:33 AM   #4
Rewards Points: 103
I need to remove old grout because it is in a very bad condition.
Old 03-02-2012, 06:51 AM   #5
DIY staff
Rewards Points: 7,174
How wide is the grout line? I use a hand cutter for small jobs (thank you Blondsense) and a multi-tool with diamond or carbide for medium sized jobs (Thank you Joe)
For a real big job--there are specialty tools available---I don't do that kind of work,so I don't own them.
Sadly---grout failure is almost always a symptom of a tile job coming loose---Tap on those tiles--If they sound hollow--you will be better off removing the tiles and starting over--Mike---
Sanded or unsanded grout for the shower surround wall tiles? nitting Tiling, ceramics, marble 10 11-30-2012 08:45 AM
How can I remove grout sealer white taint? sukhenkoi Kitchen & Bath Remodeling 2 07-29-2011 10:52 AM
Wait to seal if I need to remove haze on grout lines? PatrickGSR94 Tiling, ceramics, marble 2 04-07-2011 09:05 PM
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 07:07 PM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 10:59 PM
