How To Remove Adhesive From Off Top Of Wood Cabinets After We Removed Laminate - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-17-2013, 03:59 PM   #1
how to remove adhesive from off top of wood cabinets after we removed laminate
how to remove adheshive from wood cabinets after we remove laminate
daisylou513 is offline   Reply With Quote
Old 05-18-2013, 03:44 AM   #2
Too Short? Cut it Again!
If proper contact cement was used, you may not be able to get the laminate off. If you can, you will have to try and break the adhesive down with a solvent that will be nasty stuff.
If they were factory cabinets they may have had heat activated adhesive that was put in play with something akin to a photographic dry mount press. You may be able to get most of it off with kraft paper, a hot iron, and patience.
What is your goal in this? If it is just particle board under the laminate you are likely going to chew it up to the point it may not be useable.
Old 05-18-2013, 11:46 AM   #3
Rewards Points: 81
Methyl ethyl ketone will make quick work of that contact cement, but it is a nasty irritant, is highly flammable and can cause birth defects, so you should DIY instead of having your pregnant wife do it for you.
one cut is offline   Reply With Quote
Cabinets To Go! CapnHawk Kitchen & Bath Remodeling 63 01-10-2017 06:50 AM
do new cabinets get installed on top of existing laminate flooring mjp3513 Flooring 8 01-31-2012 06:51 AM
Laminate wood flooring on slab newb questions shark974 Flooring 3 11-11-2011 06:57 AM
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 11:42 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
