How To Remove 3 Inch Shower Magnet From Metal Door Frame - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-21-2011, 11:11 PM   #1
Exclamation
How to remove 3 inch shower magnet from metal door frame
Hey DIY people!
I'm having a tough time getting this shower door magnet that is wedged into the frame out. Should I just get some pliars and yank it out or should I unscrew the frame? I really don't want to have to do that and mess anything up. Please take a look at the photo attached.
THANKS!!!!!
Drywallhelp is offline   Reply With Quote
Old 07-21-2011, 11:21 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Another photo done with an electron microscope!
What the heck is that?
I have never seen any kind of a magnet with a shower door, I'm going to learn something new maybe.
XXX
Old 07-21-2011, 11:42 PM   #3
http://www.technologylk.com/shower-d...lk-FSDMC1.html
I think this is the actual 3 inch magnet assembly in the door frame. It looks like I should just pry it out, I don't think it has screws, but its so rusty I can't tell.
Old 07-22-2011, 07:44 AM   #4
Is this what you have?
I'd be willing to bet that one way or another it's screwed in.
Maybe clean it up with a wire brush to see if you can expose the hardware. It is possible its screwed in from behind, but this picture I posted appears it's screwed through the face.
GottaFixIt is offline   Reply With Quote
Old 07-22-2011, 08:27 AM   #5
It is the one without screws, I was able to scrape off a lot of rust to see. For some reason the image isn't showing on their website at the moment, but I think its this one:
Old 07-22-2011, 11:08 AM   #6
If that's it, it looks to me like it has clips that you would need to rotate it to disengage it.
Hard to tell from the picture, though, Maybe the clips are bent into place through slots in the frame...
Old 07-22-2011, 11:12 AM   #7
Yeah its really on there, I'm going to try to get a needle nose pliars to it and twist it out. I was told by the guy I bought the part from it may be siliconed on which would be tough to remove without heat, which I only have a hair dryer for.
Tags
magnet , shower
How to remove metal fence posts? sk8z Landscaping & Lawn Care 17 04-04-2012 04:54 PM
Remove gold finish from shower fixtures? howagood Plumbing 1 07-26-2008 10:47 PM
Tool to remove metal? darsunt Building & Construction 5 05-16-2008 03:01 PM
How do you remove plastic coupling nut and washer from braided metal connector? tony__s Plumbing 3 05-15-2008 10:15 PM
Unable to remove Shower valve abacuslearns Plumbing 8 10-27-2007 10:10 AM
