How To Properly Finish Around Sides Of Tub? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-07-2010, 08:46 PM   #1
How to properly finish around sides of tub?
The plan was to only tile to the edge of the tub, but I'm at a loss as to how to finish the sides. The other edges of the tub will be covered by cement board when I tile, but what are my options for the sides?
HenryG is offline   Reply With Quote
Old 02-07-2010, 10:10 PM   #2
Normally the same way, with cement board and tile. If you have the room I would add other stud to the end of the wall. This will give you a little more room to add cement board and tile. If you are adding a stud now is the time to be sure it plumb when installed. Makes the tiling alot easier.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Old 02-08-2010, 01:45 PM   #3
If tiling this area as well is the best option then I will change things around to accommodate this.
I checked and adding another 2x4 wouldn't really be an option. Just across from this is a pedestal sink, and I'm afraid the space is already too tight.
What is the best way too attach the cement board? The fiberglass obviously isn't flush with the studs, and I was under the assumption the cement board shouldn't be attached to the tub at all. This doesn't leave me much room. How should I address the uneven surface, and how should I attach the board before I tile?
Old 02-09-2010, 01:16 AM   #4
I normally shim the wall out even the flange of the tub. The cement board is installed over the flange 1/4" above the base. I know that others install the board on top of the flange, however this is not the way I do it. (never had a call back) A moisture barrier should be installed. This can be done with 6 mil plastic installed before the board is installed, or use Redgard before the tile is installed. I prefer the Redgard. Do not use both. If the endwall is out of plumb, then I would strongly suggest at least a 1x4 be installed and shimmed out to plumb it up. If plumb, I would predrill the cement board and install it right over the flange down the side. If you have shimmed out the walls, the cement board along the side should be flush and plumb with the rest of the board.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
how do you properly finish trim? luweee Painting 1 06-26-2009 02:10 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 06:23 PM
